SPIDER & SPIDER CONTROL
SPIDERS and Scorpions
One of the most feared insects in the world, even though 90% of them are beneficial to our eco-system. Pest control or spider control can be tricky for reasons you may not think of. Most spiders are reclusive, hiding in their webs or ambush points, cracks & crevices.
Many chemicals won’t affect them as other insect because the chemicals doesn’t get applied to the areas spiders are hiding. Another reason being, spiders do not groom themselves like other insects, so they don’t ingest the pesticides. They also walk higher off the surface doubling their chance of avoiding the pesticides.
With that being said, spider control can be accomplished with careful inspections and applications to harborage areas. Glue boards are a great non-poisonous tool to use for spider control. Insecticidal dusts also work well when applied to these areas.
Preventative measures should be used in any spider control methods. Kill the food source (other insects) and the spiders will leave the area. Make sure plants and vegetation is away from the house, door seals leave no gaps, and all window screens are repaired. Avoid leaving lights on out-doors on the house so not to attract flying insects or other drawn to the light
MOST FEARED:
Black Widow spiders and the Brown Recluse are the most dangerous spider in our area, that is the most venomous. Spider control of these are the most common calls we receive. Black Widows are mostly found outdoors, around wood piles or corners of a building or downspout. Routine pest control service can keep them to a minimum. Brown Recluse control can be a little more difficult to achieve as they hide during the daylight most often. They are also found outdoors in wood pile and undisturbed areas..
They tend to stay in areas that are not disturbed much, storage boxes, closets, drawers. They are hunting spiders and like to hunt at night, and most bites are a defensive action to them. It is said that most of their fangs, are not strong enough to puncture human skin alone. Needing a slap or weight of clothing or shoe to penetrate. Children and the elderly are more susceptible to these bites, no bets on the bigger ones.
Glue boards are very useful in monitoring brown recluse spiders. If you have a spider problem, give us a call.
417-782-1877
Spider Control in Joplin MO
Possibly, the most feared of in the insect world. Spiders are common in homes and businesses throughout the Joplin area. While most spiders are harmless, they can still be unwanted guests inside your home. Professional spider control in Joplin MO helps reduce spider populations and prevents them from returning.
Spiders often enter buildings searching for food and shelter. They are commonly found in basements, garages, attics, and corners of rooms. Webs around windows and ceilings are often the first sign of a spider problem.
Our spider control service focuses on treating areas where spiders live and hide. By reducing insects around your home, we also reduce the food sources that attract spiders.
Common Signs of Spiders
You may need spider control if you notice:
  • Spider webs in corners
  • Spiders around windows
  • Egg sacs
  • Spiders in basements or garages
  • Increased spider activity
Seeing one spider occasionally is normal, but frequent sightings can indicate a larger problem.
Why Professional Spider Control Works
Store-bought sprays usually provide only temporary relief. Spiders often hide in cracks and hard-to-reach places where sprays cannot reach.
Professional spider control provides:
  • Thorough inspections
  • Targeted treatments
  • Long-lasting protection
  • Reduced insect populations
Regular service helps keep spiders under control year-round.
Safe and Reliable Spider Treatments
Our spider control treatments are designed to be safe for families and pets when applied properly. We treat both interior and exterior areas to help prevent spiders from entering your home.
Exterior treatments are especially important because spiders often live around foundations, siding, and windows.
Call for Spider Control in Joplin MO
If spiders are becoming a problem, professional spider control can help protect your home.
Contact us today to schedule service and keep your home spider-free. For more information on Black Widow’s and Brown Recluse check out this link: MDA
We also do Ant Control
SCORPIANS of Our Area
In the Joplin, Missouri area and across the Ozarks, the most common scorpion is the striped bark scorpion (Centruroides vittatus). These scorpions are typically light tan or yellowish with two darker stripes running down their back. They are relatively small—usually 1 to 2.5 inches long—and are mostly active at night.
Striped bark scorpions prefer warm, dry environments and often hide during the day under rocks, log’s, leaf litter, or even inside homes. Indoors, they are commonly found in basements, crawl spaces, bathrooms, or along walls and baseboards. They can climb walls and ceilings, which sometimes surprises homeowners.
While their sting can be painful—often compared to a bee sting—it is not considered dangerous for most healthy adults. Symptoms usually include localized pain, mild swelling, and redness. However, young children, elderly individuals, or those with allergies may experience stronger reactions and should seek medical attention if symptoms worsen.
Scorpions feed on insects such as crickets, roaches, and spiders, making them beneficial in controlling pest populations. Preventing infestations involves sealing cracks, reducing clutter, eliminating excess moisture, and controlling other insects that attract them.
One really cool fact about scorpions is that they will glow under a UV light. Even dead ones will glow!
Around Joplin and Galena we often find them near chats or rocky terrains. Seems to be their spot. for more information on Bark Scorpions check out this site, MDC
Photos from Missouri Dept. of Conservation
Scroll to Top
